I have an 86 GN and an 85 regal with v6. I have the same problem with both cars. A new battery, a good alternator (13.8-14.1 volts) but the battery will not charge. Garyk1970 helped me with the 85 by running a wire from the alternator to the fuse box and I had to put a diode in it. I never attempted to repair the GN yet b/c I never drive it. Well, now I have the problem again with the 85. I am not getting 12 volts continuous power to the fuse box is the reason it will not charge now (through the wire that I ran several months ago), but I would like to repair them both the right way. Can anyone tell me where the fusible links are in the 85 N/A v6 and the 86 GN?? I believe if I make repairs to the fusible links, this will eliminate both of my problems.
Also, on the 85, I still have power to the fuse box on the ignition terminals, but no power to the continuous 12v sources that are labeled battery. I don't get it, and now I am stuck driving my truck!!!! I know none of you want that, so PLEASE HELP!! BTW, Gary is out of town on business and will not be back until WED.
