Take a photo of the both plugs and post'emOnly one of my fans are coming on. I have a Casper engine harness that eliminates the low speed relay. Could this be the issue?
Aaron I'm having trouble posting pics with the app now. Here is what is happening... Is this normal for this setup?
The passenger side fan is chip controlled and the drivers side only comes on with a/c or if I ground the a/c switch. That is the only way I've gotten both to turn on. Is this how they are supposed to be configured?
OK so this would require me to purchase a additional wire harness to make it a manual function ? I got the complete harness that came with the fan kit from alradco?2nd fan most likely would be activated by high pressure A/C switch, which won't work with a dead A/C system, and the other high speed factory trigger is around 220 degrees an intake water sensor switch.
The caspers hi/lo manual switch plugs in parallel to the A/C high pressure switch connector.
It allows you to manually activate it on HI speed inside the car, or low speed, or off which is factory default wiring, since the A/C pressure switch can activate both Hi and Lo fans depending on the A/C high pressure value.
You wouldn't need a functioning A/C system to use the caspers switch but the fan wiring must be intact and working properly.
I can't see on my phone your signature so I don't know if you are running stock ecm. If you have an xfi, you will have to trigger it (second fan). Have you checked your high speed relay or tried grounding your pressure switch to see if you can activate it .Hmm. Can I jump in on this conversation please. So I'm having a similar issue but mine is that my driver side fan come on 1st which is the thicker fan I have a slim 1 on the passenger side but that 1 never seems to come on. I turn on my a/c switches even though it blows air only out of my top vents and no cold air but that does not engage my second fan anyway? I've gotten up to about 200 on temp and still haven't seen the second fan come on?
