All kinds of parts, stock to aftermarket
RobCrisafulli
http://new.photos.yahoo.com/rob_crisafulli/albums
look in the Buick folder.
Prices do not include shipping. I can take money orders or paypal.
2 GM 14 bolt oil pan gaskets cork, new
2 GM 2004R trans pan gaskets, new
1 Victor valve cover gasket set, steel shim and cork, VS 39763TC, new
$50 for all 5 gaskets
SPAL dual fan setup, new, $150
MSD Digital DIS4 PN:6215, everthing you need to bolt in a go.
includes coil pack, coil pack adapter and bracket, used, $400
Casper Plug wire tester, used Casper Coil pack tester, used
both for $100
GM Crank position bracket, bolt and sensor, used, $25
GM Cam sensor, new, $80
GM Cam sensor, very low miles, $40
2 GM Fan delay relays, PN: 25537402, new, $75 each
GM Fuel pump relay, PN: 10038490, new $10
FAST ECU data logger, used, $50
The Buick Book 1987, The Buick Buyers Guide 1987, 1987 Buick Exterior colors and wheels, all three for $25
K&N valve cover breathers, 1 new, 1 used, both for $20
LT1 starter, barely used, $70
Very low miles on these parts:
Alternator, $65
tensoner with pulley, $65
A/C bracket, cleaned and glass beaded, $25
Front cover, cleaned and glass beaded, $40
coil pack bracket, $10
Turbo Regal tranmission dipstick and tube, cleaned and glassed beaded, $20
TTA tranmission dipstick and tube, $20
Constant torque clamps:
1 - 2.5 inch CT250
5 - 3 inch CT300
all 6 for $20
ARP Flywheel bolts, used $20
Aerospace Components Rear calipers with PAD. used very little, $100 for both
Stage 2 heads bare unfinished, seats, no guides, valve covers and front cover. No port work done, out of box $150 for everything
TTA dash wiring, fuse panel side and front bay harness. Does not include turbo engine harness, includes pass key, lots of relays and electical parts, switches, fan delay, fuel pump relay, wiper stuff, head light stuff, look at pics carefully. tons of stuff, Great deal for $125 everything
Robert
rob_crisafulli@yahoo.com
I will take
and FAST ECU data logger, used, $50
I can send you payal My zip is 92881 business address let me know what shipping will be.
I would like the TTA dip stick $20
The GN dipstick$20, and the new cam sensor$80.
And the A/C bracket $25 if this is the aluminum accessory bracket.
Please shoot me the price including shipping to: hipsibri@cs.com
Thank you, Brian
Parts
I want:
GM Fuel Pump Relay, PN: 10038490, new, $10
LT1 Starter, barely used, $70
AC Bracket, cleaned & glass beaded, $25, (oops, 2nd in line)
Shipped to 78023, let me know a price.
Thanks.
Stage 2 stuff sold and ECU logger.
I will try to respond to everyone tonight. Sorry for the delay.
The ALT is factory GM, not sure what the amps is. I can check and see if I can find something on it.
Thanks,
Robert
Everyone,
brakes are sold
sales pending on:
FAN and TTA harness stuff
fuel pump relay and starter
coil pack bracket
tta dipstick, gn dipstick, new cam sensor and a/c bracket
used cam sensor
alternator
Check you email or PM's
Thanks,
Robert
PS: saves time if you email zip code when you want something.
Payment info sent for the above parts.
Thank you Robert.
Brian
