OK.. New battery.. New ignition switch... Checked bulkhead, fuse links, grounds, tightened up all terminals, connectors, etc... STILL losing almost 3 volts at the alky pump... Started checking in the car at the controller... With the pump commanded full duty it looks like I'm losing 1 volt through the GROUND circuit of the controller: I checked voltage on the red wire, pump output side of the controller with the ground lead of my meter attached to the dash where the controller is grounded.. I measure 13.4 with the car running.. I moved my meter ground lead to the same side as the positive lead, on the output side of the controller and it drops to 12.4 volts.. So there's 1 volt loss.. Still need to find the other 2...
