christians87
- Jul 23, 2007
Ive tracked down a vacuum leak inside the car to be the air flow selector switch. The switch above the temp adjustment on the dash. Has anyone else had this problem? What is leaking is the actual round selector on the back of the pannel that is hooked into the multi colored vacuum lines. Can that be replaced or do I have to replace the whole switch panel? Where can I get one? Thanks..
