In trying to get an aftermarket 3" DP installed on an '87 T, I noticed that the rear of the DP was hitting the frame. There is no "slop" in the mounting bolts to allow the rear of the DP to go upwards. ( I left the bolts very loose). So I started looking at the possibility of the motor mounts being the issue. I have new aftermarket (Pioneer) mounts on both sides. I compared them to the original worn (squashed) GM mounts that I took out. I measured the passenger side worn GM motor mount and got approx. 2-1/2" from center of the frame pad bolt hole to the backside of the mount where it bolts to the engine. On the new Pioneer mount I got 2-3/4" for the same measurement. So in my case, the new mount is actually 1/4" taller than the worn one. So this should be helping me. The driver's side measured about the same.
Anybody else experience this or have any measurements?
I have also replaced the headers with Poston's so they may have introduced an angle where the turbo mounts that is compounding the situation.
