AC replacement questions
rphatdad
I recall hearing that a different car model ac evaporator unit or condenser was better than stock. I am replacing compressor evap and condenser what should I buy.
What other car is there?
No, evap core is vin 7 specific. If I'm wrong lmk because I only found one place that produces them and they were all out of stock. I assume because nos4gn bought them all as they are the only place I know of that could have them in stock at some point. Now, you can use a different orifice tube from a f150, 90s I think. Supposed to help get the a/c colder. I used all stock stuff and it seems to cool just fine, even with the front mount and crappy stock fan with the car running over 190. TOday the heat index is 102 FYI.
If possible I would just have the core fixed and throw it back in. Good luck. The shop that did all my stuff fucked it all up and I had to raise hell. Had to put new fittings back on, among other things.
