Greetings!
I read the related posts from the archives and I still have some questions.
I had the system converted to R134a a couple of years ago on my '87 GN. What happens is that the clutch will momentarily enguage when the AC is first started when I do a cold start on the engine. The air blows cool for about 30 seconds, then just vent.
I bought one of those recharge kits and it came with a low-side pressure guage. It reads in the red at 110psi (I'm connecting it to the accumulator, where I would add refrigerant).
Looking at the diagrams from the good book, it shows a pressure switch, a A/C cutoff relay, and wires going to the A/C unit via 2 connectors. Now, I found what looks like a pressure switch (2 wires, female connector) on the side of the accumulator. Only it has a Lt. Grn wire and a Dk. Grn wire on it.
On another inline switch, there is a 3-wire connector. The colors are Dk. Grn, Dk. Grn/Yel, and Blk/Wht.
Ok, now that I'm totally confused, any suggestions?
Thanks in advance.
-Grinch
Thanks in advance.
-Grinch
