SFI Cutlass check out this link it may or may not help. Alot of info so I just fund the link figuring it would be easier then typingLooks good Brian. I was going to say to put the speedo and tach in the middle with the smaller gauges on each side but the cutlass dash does not allow that. With these gauges I'm assuming the speedo is electric and the cable would no longer be needed?
On another note I was wondering if you would know why my cutlass tach gives me an erratic read? It would used to work absolutely fine without problems with the 307 but with the 3.8 after warm up it will start to jump all over the place. I've solder a piece of wire in the back of two different tachs but after warn up I have the same results with rpms jumping all over the place. All my other gauges work without any issues except the rpm gauge?
Bweavy said:SFI Cutlass check out this link it may or may not help. Alot of info so I just fund the link figuring it would be easier then typing
http://tech.oldsgmail.com/eint_tach_fix.php
I see you soldered the wire. If this doesn't help I can send you a good known v6 Olds tach & we can try & walk thru this & figure it out.
We are shooting for $299. Then upgraded a few things like the aluminum plate that holds the whiskers to a thin steel. Other brackets, tweak this improve that make this better you know. So we are saying $350 now to be safe & with a 10% kick back to hurst $385. Now I know if it comes in cheaper we will not have any complaints .So when are the lightning rods available? wasnt the price $299? Is there a plate available for the buick dash to put custom gauges in?
Bweavy said:As far as a Buick dash we could have 1 built. Shoot me some ideas. GNX thing has been done to death .
Not arguing with you. I tell you who had the nicest set up is Barron with the Power 6 logos on his gauges.Done to death but no longer available at a reasonable price!
There really is no reason there needs to be a $2,000 set up. Should be a kit where you can build your self or just buy a completed kit & install. Then every where in between.
Sounds like you have a new project
