If you don't have one, get a line lock. Doing a brake burnout can heat up the rear brakes and allow pushing.
The trick to to leaving with more boost is to trick the convertor and brakes.
Boost to as much as the brakes will hold (in your case, about 5 psi) and as the tree comes down, rapidly mash the accellerator to the floor, while still holding the brake. Release the brake and go.
The rapid WOT will slightly bog the car, while making the turbo go to full spool. The result is your leave will be closer to 10-15 psi.
It takes a little practice to get the technique down, but it is the best way to launch a stock converter car, especially when you have enough tire to take the shock.
If the spool is lazy, make sure there are no preturbo header/crossover leaks, your FP isn't too high and definately try another chip to see if you can lean out your launch.
