BOOSTBROTHER
just spooling around
- Aug 18, 2004
For sale 1996 F250 reg cab longbed 2wd POWERSTROKE 5spd K&N air filter Edge power programer 60/80/100 hp 80/120/200 tq I run it on the middle setting all the time. The clutch is in great shape I just put 8 new glow plugs in it, a/c is ICE cold and the heat is even better.The front tires are new (10ply) rears 50%, the front end is tight and it drives like it was new. I put a new seat in 6mo ago it has a new water pump on it. This truck gets 20-21mpg (3.55gears) and 16-17 mpg pulling an enclosed trailer. If you need a dependable work horse this is the truck for you. I have owned this truck over two years and have put 60,000 miles on it. The truck is white with gray guts just turned 240,000 it does not use any oil. The windshied has a small crack on the pass side. You can drive this truck home or pull a trailer home it is ready to go.
$5,500.00
I will try to get some pics.
BOOSTBROTHER
$5,500.00
BOOSTBROTHER
