95' Caddy Fleetwood Brghm Triple Blk. 13sec 1/4's W/xtras....
TURBORUSTY
the car is a 95' cadillac fleetwood brougham with 125k miles on the body and engine.car has a 260hp LT1 powerplant with these mods:52mm t/b,re-programmed pcm(pcmforless),1.6 rockers,accel 9000 cables,brand new opti spark complete,edelbrock billet double roller timing chain,meziere heavy duty electric water pump,hooker longtubes,earls replaceable header gaskets,complete 2.5" exhaust system dumped right after axle w/magnaflow muffs.pro-built 4l60e with about 8k miles on it,vette servo,energy suspension mount,yukon deep pan,4000 9.5" Stall,brand new Eaton Posi unit 800lbs springs,Strange gears 4.56's,chrome diff cover,new axle bearings,d/s balanced to 4000 rpm's by local d/s shop, KYB front shocks,Comp Eng 3way adjustable rears,H&R front & rear springs about a 4-5 inch drop from factory,front brakes rotors pads and calipersoem equip,walbro intank f/p,auto meter vaccum guage with pod, brand new optima RED battery, ALSO SCANMASTER LT1.engine is also dressed up with corvette lt4 composite valve covers and vette fuel rail covers.
i had also added a EXTERNAL P/S,TRANS,OIL COOLERS all from a police application caprice.it has 9c1 rear sway bar and 32mm front 78-80 swaybar with energy suspension bushings.car has no emissions componets on it.
car is black on the exterior with a blue front clip ,black leather interior small tear on drive side seat,PW,PL,TILT ICE COLD A/C .it has a black rag top from factory this was an EX-funeral car R1P SPID CODE.
so for a good portion of its life it was serviced in funeral proccesions.before i got my hands on it.
it will come with black police 9c1 wheels with brand new 235/60/15 tires on them with center caps.
it has a panosonic cd player along with all 4 speakers have been upgraded & 4 tweeters where added power antenna still works up and down as well as the power seat and heated seats, and power mirrors.
car has no major dents just several small dings, all chrome is on bottom 1/4's of the car,missing plastic trims on each corner of the front bumper $15 each on ebay, also rear plastic long strip is broken on one corner.car has no rust on frame,floor or 1/4's of the car this car was a down south car with cery little wear the steering wheel is still intact.
this car has clocked consistent 13.7 and 13.8 @ 98mph 1.8 60' passes on a d/r in hot weather very sticky hot weather on pump gas driven to the track and back home with the a/c on in a lazy boy type recliner seat gets no better all you need is beer and a woman and youre set.
all this car needs is a paint job as i said complete front clip is blue from fenders forward it had a smal fender bender up front and i decided to change it all to one color and 1 of the fenders had many dents prior to altercation.vinyl top is in great condition with no tears.
looking to get $7000 o.b.o. or trade str8 up for a 86-87 turbo -t or GN
AND TO ADD:
just finished installing a small street cam in the car. now must be in low 13's to high 12's...with at least a 105 mph also all valvetrain components where swapped to support cam.has all new gaskets motor is completely sealed with no leaks and does not smoke.
compression check on all 8 cylinders was found to be 190 across the board on all 8 cylinders with no difference between them.
really healthy motor just got even better.
STILL LOOKING FOR A TURBO BUICK...
just finished getting back from my local 1/8th mile track. the car went 8.80 @ 78mph w/ 1.85 60'
this was also with the speaker system and a friend sitting inside the car.
i also just added a Sound System to the car which is composed of 2 12" INSIGNIA brand speakers with a 1000w INSIGNIA amp, i will be installing an amp for the mids and highs real soon to complete sound system for the car.
$5000 o.b.o.
ttt...
front clip has been completely sanded down and BLACK PRIMERED. I be fixing 2 drivers side window rollers in this coming week. will try to post pics with new primer paint job.
heres a lil engine pic $4500
Overall shes runs great i get about 15-17 mpg overall average. she idles just like stock but with a nice crispy 112 lsa on the CC502 it has a bit of a chop at idle.pulls just like any other car its not unbearable to drive the car its just impossible not to give her a lil gas whenever called upon.now form light to light theres nothing to keep up with it, on the e-way with the 4.56's the car runs at 3000 rpm at 75 mph with no problems no leaks, no smoke, no noises.
so to sum it all up yes it runs very smooth and crisp very responsive, kicks down whenever asked.
this car gets driven to the track which the closest one to me is 100 miles away thats 200 miles total for a pass at the track, the car still has a/c,system and a real nice lazy boy recliner to ride all the way back down from the track in.
Buyer BEWARE
This guy has a bad history on the B body boards check the link you will get the idea.. Rusty I don't know you but I hope you will take my advice in the other thread over there, I meant it sincerely. Sorry but I got to look out for my Buick brothers.
i am selling car for my FATHER nothing to do with me car can be seen in person and reviewed thourghly before purchase.
previous problem on the b-body board was over a TEMP GUAGE $32 which was damaged during shipment just think you should tell everyone why it is your posting.
thanks you.
