I'm going to be selling my 200 and doing a trans swap this winter and am looking for some information on trade-offs between the good ole 400 and the 4L80e.
My goal: Reliable trans for mid-9s, trans brake, OD. Would this best be met with a 400 and a GV OD or a 4L80e?
I've done a fair amount of sifting through the archives here, but I'd like to better understand the trade-offs around a couple of areas:
I'm Philly-based and have a number of good choices in terms of good trans shops to work with (CK, Michael's Transmissions, Deltrans, etc.). My thanks in advance for the help in thinking through some of these trade-offs.
Scott
- Weight: Is there a major wet weight difference between the 4L80e and a 400 WITH the GV overdrive installed (assume good converters for each)? My sense is no, but there's a surprising lack of clear info on what these weigh around.
- Efficiency: What's known about efficiency / parasitic loss differences between the two? Suspect it's not enough to care about, but am curious.
- Control: Does the electronic control of the 4L80e (via TCI trans controller or whatever...) work reasonably well? I'm running XFI, but always shudder a bit at adding another electronic controller to the combo.
- Durability, install, and cost: If well built, both should more than handle what I'm going to throw at it, but any differences expected in the frequency of refreshes I'd be looking at? Any significant differences in install requirements between the two in terms of modification, fabrication, etc...? Finally, this isn't going to be a cheap trans, but are there any cost considerations too factor in beyond the trans and converter for each? About where do folks think I'll end up in $s for a complete setup including controllers, install bits needed, etc...
Scott
