87 Turbo T white hard top w/ blue interior. 18400 miles/ stock bottom end, ported heads ,intake, throttlebody. TA49 w/ blue top injectors, intank and external fuel pumps. Stock headers ported and welded. Extended stock location intercooler, Dynotech trans w/ Art Carr 9 inch converter, eaton posi rear, ssm lowers, airbags. Bf goodrich drag radials. Do not have stock rims. Scanmaster, 2 1/2 dual exhaust, Roll bar w/ removable side and rear seat bars. Very nicely done through the side of the rear seat. No damage to package tray. Easy access to rear seat. Interior has sagging headliner and 3 gauges were drilled above radio. Otherwise mint. Power antenna does not work. Car has had 1 repaint by previous owner. Not show quality, about a 5 footer. It was masked off not completely disassembled. (ex. lock cylinders and handles) Small spot peeling on rt. front fender and left corner of header panel, not too bad. Went to track last year on pump gas 16-17 lbs of boost, car went 11.6 @116 w/ 1.7 60 ft on bf goodrich drag radials. Second owner, first was Fred Vetter. Located in NJ, I will attempt to add pics. If not, Email tflo22@yahoo.com. 11,500.
