turbojkt
- Feb 1, 2003
OPTIONS:
Designer two tone paint, leather seats, PW, PL, Twilight Sentinal, factory alarm, digital dash, cornering lamps, concert sound, moon roof, tilt wheel, limited slip. Sticker price in 1987 was $19,333.00. SEE ORIGINAL STICKER at Photo Bucket link below.
I purchased this 1987 Turbo "T" new. Ordered it thru a dealer from the factory in the Spring of 1987, and it was delivered in August. I considered ordering a GN, but the dealer said that only dealers with a certain volume of sales could order those, which was fine because I liked the idea of getting another color besides Black. It has been driven only in dry weather, and garaged it's whole life. Still has the factory paint. Not one bit of rust on this car. I have most of the parts to return it to stock condition if someone wanted to do that...except for the innercooler. I have the scoop, but not the innercooler. The heads still have the factory seal. I replaced the timing sprocket, chain, camshaft, and lifters at 112,000 miles a few years ago. I think one of the lifters is bad because it has a noisey ticking sound and then it's using oil. 117,000 miles. Ran a 12.4 @ 115 in this condition when I had a TE62 turbo on it.
Results from a recent compression test:
1. 130
2. 130
3. 130
4. 135
5. 135
6.130
Mods and Parts:
Stretch Innercooler w/duttweiler neck, XP Fuel pump hotwired, 4 core radiator, Spal High Perf Fan, RJC billlet pulleys, Kirban Touch and Go alarm, line lock, driveline loop, air bags, KYB shocks, pinion snubber, UMI upper and lower control arms, one inch rear sway bar, Kirban body bushings, Kirban rear seat brace, fuel press rail gauge, adj fuel press reg, torque strap, RJC deep oil pan, biggie oil filter adapter, EGT gauge, pillar mount boost and knock, 15 X 8.5 vector chromed wheels on the back, 15 X 7 stock chromed on the front, original stock wheels and center caps in excellent condition, Kenne bell oil booster plate, powder coated stock headers, AC Delco Radio/CD player, TA49, 50lb Inj, 210/210 cam, factory sealed heads with roller rockers, RJC Power Plate & Boost Controller, Houston 3 in. DP, RJC 3 Inch Dual Exhaust, Volt Booster, SMC Alcohol Inj., rebuilt trans with 9 1/2 Vigilante multi-disk converter, original catalytic converter with 3 inch inlet (hasn't been used for many years) Price includes both sets of wheels and all the original parts from the car.
Asking $13,900.
Pictures & Video Here:
1987 Limited Turbo T pictures by turbojohn - Photobucket
Listen to the motor here:
YouTube - RJC Racing Exhaust System on Buick Grand National Turbo T
1. 130
2. 130
3. 130
4. 135
5. 135
6.130
Mods and Parts:
Asking $13,900.
