ok car has 60lb motron injectors, tt 5.7 alky chip, te60 turbo, and eastern performance intercooler, lt1 maf with translator, new fuel pump walbro 340. are idles but has a slight miss when you put it into drive it runs really bad and shakes and if you hit the throttle it barely wants to move. if you snap open throttle at idle some times you here a pop coming from the intake. if you try to drive it boost doesnt want to go past 1psi. turbo was replace 2 yrs ago
scanmaster readings are below
clt 178
ats 97
rpm 900-925
tps.42
iac 66
af 07
l8 42
int 128
bl 142
clt 178
ats 97
rpm 900-925
tps.42
iac 66
af 07
l8 42
int 128
bl 142
