5.3L iron block engine built and assembled by Jensen's Engine Technology in Nescopeck Pennsylvania. This engine is not ran, and is currently wrapped in shrink wrap in my garage on an engine stand. Specs are as follows:
5.3L iron block bored to standard LS1 bore (3.898")
Factory 5.3L crankshaft
Compstar connecting rods
Custom JE pistons designed for a turbo
Custom comp cams camshaft designed by Andy Jensen
Comp timing set
SFI Damper
ARP studs throughout
Ported oil pump
Factory 317 heads with valve job, bowl work, new springs/retainers/locks matched to cam
Sheet metal oil pan
GZ motorsports vacuum pump
Front and rear motor plates
Etc.
Well over $7000.00 invested. I have most of the receipts and all of the paperwork from Jensens, including the piston specs and cam card. This engine is ready to go and is capable of making a LOT of power. $6200.00 OBO.
Also available:
TV7512 Turbo - $350 OBO
Exhaust manifold flanges and fittings to make log style turbo headers for LSx heads
RJC Megacooler 4.75" thick, 3" in and out - great shape - $650 OBO NO PIPES!!!!!!!!!!!!!
Precision 46mm wastegate like new -- SOLD
Tial Blow-off valve -- $165 OBO
9.5" torque converter from PTC converters (over $900 new) -- SOLD
Powerglide with ultrabell built by Kool Kar Performance in PA, less than 500 miles and 20 passes - SOLD
Cheetah shifter with aluminum mount -- $175 OBO
Two Kirkey pro drag seats with black covers like new -- 15" width -- $400 OBO
Fuellab fuel pressure regulator, never used -- $100 OBO
Weldon 2035 Fuel pump -- 1800HP capable, refurbed by Weldon with pump curves -- $550 OBO
Turbo buick (86-87) ported factory intake manifold -- $200 OBO
Turbo buick factory block with RJC girdle and hardware - SOLD
G-body TRZ rear lower control arms single adjustable like new -- SOLD
G-body TRZ rear upper control arms double adjustable - SOLD
G-body Bell-tech 2" drop spindles - $155 OBO
Factory LSx computer 99-00 Serv #09354896 - $50 OBO
Factory turbo crank - $75 OBO
Factory turbo crank that was balanced with 50% weight on bobs (has a couple slugs of mallory metal in it - $75 OBO
Rolling Chassis:
87 cutlass, dark blue with 12pt mild steel cage, rust free!!
This chassis is set up for the 5.3 listed above, the intercooler, the powerglide, etc.
Ford 9" rear end with wolfe racecraft control arms
Adjustable front upper control arms and rebuilt lowers with afco ball joints
Wilwood brake pedal
Tubular trans crossmember
TRZ steering column
Custom aluminum dash insert with many autometer gauges
HR Parts chromoly sway bar
3" steel driveshaft
Body was separated from frame in order to do some bracing and make solid body mounts
Mini-tubbed
Cragar Pro-star wheels
Lots of extras and lots of work
I will not separate anything off the chassis that makes it not movable
$5500.00 OBO
If you have any questions or want pictures send me a PM or email at jrdepew@gmail.com. I have TONS of pictures of all this stuff so let me know if you want to see anything.
Location is around Binghamton, NY.
Thanks for looking,
Joe D
Comp timing set
SFI Damper
Ported oil pump
Sheet metal oil pan
Etc.
Also available:
Rolling Chassis:
Wilwood brake pedal
TRZ steering column
3" steel driveshaft
Mini-tubbed
$5500.00 OBO
Thanks for looking,
Joe D
