$2350
Located in Kingman, (100 mi from las vegas.)
455 BBB. completely fresh / new 455 buick. std bore.
crank magged, 10-10, new stg 1 cam, rings, brgs, cam brgs, lifters,
freeze plug, 3 angle valve job, guides cut for high lift cam, viton seals,
edelbrock roller timing chain,
spring pressure set for stg 1 cam, both front and rear main seals are upgraded, ( no rope)
oil pump clearances set, comes with valve covers, rocker arms, pushrods
this is a stock build, no oil, needs primed!!!.
no intake, dist, water pump. fuel pump, flywheel
