Well the gn is just about stock running 17 pounds of boost, and it seems like it launches out of the whole quick enough 2.0 60ft but kind of looses the pull and mph 90. Just bought the car about a month maybe 2, and the exaust is just crap so i made exaust cut out before cat (2 1/2). So people keep telling me to get a 3 Inch down pipe which costs some money and i wanna know if its going to help. i do have the 3 cut out and test tube ready to bolt on after the get my new 3 dp.
666al. You're off to a good start with the new mods. That's exactly what you should have on there.
Tell me this. What sort of cold air intake do you have? Is it just a filter thrown on? Is the filter mounted outside the engine bay? (not that it has to. most here do not, including myself. not really necessary) Do you have a maf pipe in there?
And explain your chip? At this point in time, your next mods are these. Oil pressure gauge, boost gauge, turbo tweak chip, fuel pump w/ hotwire kit, new valve springs, rjc power plate, and bigger rear sway bar. The power plate distributes the airflow to all cylinders, to prevent certain ones from leaning out. NEVER turn up the wick without one, for sure.
A thick rear sway bar really helps a launch out, and the chip smooths everything out. I personally guarantee you noticeable improvement with these mods.
After these mods are on, it's tune time. tune tune tune. Make sure your O2 sensors doing what it's supposed to be doing. The turbo inlet bell, intercooler, and throttle body is free of oil, there are no vac leaks, no rotted hoses, and the temperature's where it's supposed to be. VERY important on these rides.
Make sure you have a 160 degree thermostat installed as well. Depending on the condition of your overall cooling system, and having that thermostat, and a good chip, it may be all that's needed for a cool running car. Mine runs just fine on a stock radiator with stock fans.
Where are you located?
