Installed these with 5/16" spacers to clear the frame. For months they worked perfect; no rubbing, no nothing!
Yesterday i was investigating a grinding noise while turning, so I jacked the GNs butt up and took off the rear wheels. Found the problem (time fer back brakes) and put the wheels back on.
Now it seems everything has shifted towards the passenger side of the car; the inside driver's side rear tire is rubbing the inner fender wall when I go over larger bumps.
Plenty o "larger bumps" here in chicagoland, so this is becoming quite a concern, heh heh. Any ideas what coulda changed to cause this problem?!?
TIA.
TIA.
