Hey guys
i seem to not be able to get rid of this damn 2-3 shift flare i have, i have went from a duel feed back to a single feed and with the single feed it had got better
But it seems as if the second gear/band is releasing before the 3rd gear clutch pack can be applied... almost like it goes to neutral for a split second .... the start of the shift is 5550 rpm and then hits 6200 then back to 5400......
The shift takes about 3 tenths to happen before with the duel feed was about 6-7 tenths.
Also when it was dual feed it was mushrooming the clutchs and steels ....I added a second ring into the piston to try and even out the pressure apply on the steels and clutchs.....
that didn't really help .. so i went back to a single feed and now i'm almost there.
Thanks for any help guys
