took my engine out to investigate metalic particles in the oil and found #2 & #3 main bearings wasted. #2 was the mos damaged not spun but it was like flaking off on the lower half. The thurst sides showed ware not to bad. #3 was starting to flake off and showed dark marks like being burnt. The engine has steel caps on #2 & #3 with a girdle. Rod bearings show signs of ware. Is this an alignment , oiling or detonation problem. Any ideas? TIA Dean
