89mulletbird
- Jun 24, 2004
74k original miles. Original paint. $20k+ in upgrades. Perfect running condition.
Engine
Champion iron heads
210/215 roller cam
Polished throttle body
Billet vacuum block
RJC power plate
RJC IAC relocation block
6466BB turbo
Turbo heat shields
HR solid motor mounts
Intake
4" RJC CAI
Polished up pipe
Duttweiler neck
Fuel System
LS1 double 450 Walbro
8AN supply 6AN return
Cruz fuel rails
External regulator
160lb injectors
Hotwire injector harness
Exhaust
Terry Houston 3" DP
SLP SS exhaust
Transmission
Art Carr 750HP build
Setrab oil cooler
Braided cooler lines
PTC 9.5" NLU 3200 stall
Transbrake
Aluminum pan
Interior
Katzskins front seat covers
Electronics
AEM wideband
Trans temp gauge
Boost gauge
Scanmaster
Powerlogger
SD2 chip
Modded ECU
CS144 alternator
Optima Red Top
Battery relocation
Kill switch
Cotton cam sensor cap
Drivetrain
Chromoly driveshaft
Strange S60 3.54 spool
Driveshaft loop
Adjustable panhard bar
Body
Fiberglass spoiler
Brakes
Hawks HPS pads- rear
Porterfield R4s pads - front
New front calipers 2015
New brake booster 2011
Engine
Champion iron heads
210/215 roller cam
Billet vacuum block
RJC power plate
6466BB turbo
Turbo heat shields
Intake
4" RJC CAI
Polished up pipe
Duttweiler neck
Fuel System
Cruz fuel rails
External regulator
160lb injectors
Exhaust
Terry Houston 3" DP
SLP SS exhaust
Transmission
Setrab oil cooler
Transbrake
Aluminum pan
Interior
Electronics
AEM wideband
Trans temp gauge
Boost gauge
Scanmaster
Powerlogger
SD2 chip
Modded ECU
CS144 alternator
Optima Red Top
Battery relocation
Kill switch
Drivetrain
Chromoly driveshaft
Driveshaft loop
Body
Fiberglass spoiler
Brakes
