1987 Turbo Regal $15,000
3rdturbocar
addicted to boost
87 Turbo Regal 3.8 intercooled turbo, automatic, and G80 posi rear. I have a picture of the original window sticker but unfortunately the actual window sticker itself was misplaced.
The car has a custom black metal flake paint job zero rust or rot anywhere. The suspension, front end, and brakes were rebuilt, has new shocks, urethane bushings, inner and outer tie rods, ball joints, sway bar links, all new brake hardware with vacuum conversion. The frame is undercoated and painted. The motor runs excellent and has the following new: double roller timing chain, high volume oil pump, all new seals, gaskets, comp cams valve springs, water pump, radiator, Intrepid dual fan set up, alternator, serpentine belt, entire A/C system including the compressor-converted to R-134 as well, Cottons performance Aluminum valve covers, high volume fuel pump, adjustable fuel regulator, the newest RJC Racing IC-315-XTF front mount intercooler with polished pipes, TA-49 Turbo, Razors Alky kit, LT-1 Mass Air Translator, 60lb injectors and a Turbo Tweak custom chip burned to this set up. Exhaust has a 3" down pipe with external wastegate dumping into 2 1/2" exhaust with flowmaster mufflers. The interior is clean and has custom floor mats, center arm rest with cup holders, Scanmaster, boost, knock, oil, and temp gauges. The car also has power windows, door locks, concert sound system stereo with automatic antenna that works, twilight sentinel lighting, and trunk carpet kit. Has GNX style wheels with brand new tires. Car runs and drives excellent, very nice car located in Central NJ. Asking $15,000.
