1987 G/N Posi Rear
Mrneg9
Get Some !
This rear is from a 1987 Buick Grand National. The guy I bought it from said he had it stored for over 20 years in his garage and that it came from a low mile car that was in an accident. I bought it for a spare but will not be using it. If you look at the pictures you can see the code 3TP. 87 G/N Posi rear with 342 gears. The rear has new rubber stops installed,Polly bushings and aluminum rear cover. It will have to have new brake shoes installed and wheel cylinders if you choose. I have the stock cover bolts and tag for the rear also. Will give you stock lower arms and sway bar not pictured. $1,500 negotiable.
Must pick up will not ship.
