S slickj52003 Member Joined May 27, 2010 Feb 3, 2014 #1 Have Cragar S/S wheels and they rub so time to switch to different style; ideas? Thanks
R Rose Formerly t'squick6 Joined Jul 5, 2013 Feb 3, 2014 #2 I run centerline qualifiers with those brakes.
scot w. GNSperformance.com Joined Feb 19, 2005 Feb 4, 2014 #3 slickj52003 said: Have Cragar S/S wheels and they rub so time to switch to different style; ideas? Thanks Click to expand... You should use the SS4 brake template to see what wheels fit. I can send a link if you want then cut it out and glue it on a piece of cardboard then take that with you to the wheel store and check the template out on wheels while your there.
scot w. GNSperformance.com Joined Feb 19, 2005 Aug 4, 2014 #6 dcfny said: Do the SS4's work on a stock set-up? Click to expand... On just the front they do but the rear rotor of the SS4's are 12" so they will not fit the rear wheels...
P psycho6cyl Ponies Are For Lil Girls Joined Feb 11, 2005 Aug 4, 2014 #7 Rose said: I run centerline qualifiers with those brakes. Click to expand... you have the front and rear kit on the qualifiers? theyre 15s right?
