12 inch brake conversion
I have the 12 inch brake conversion on my '84 GN. I used the B-body spindles, IROC 1LE rotors, and the B-body calipers. For the swap to work you also have to install the Hotchkiss tubular upper A-arms. I have the alignment set at -.25 degree camber, 3 degrees caster, and .1 degree total toe-in. The car scrubs a lot less, but keep in mind its still a big soft sedan chassis. The stopping power is serious, but using the B-body calipers increases the pedal travel, which takes a little getting used to. For wheels, I'm using the 16 inch GTA rear wheels on the front, with GTA fronts on the back.
