N nboost Member Joined Nov 9, 2003 Jun 5, 2009 #1 Ive tried to search as much as i could before posting and found only bits and pieces so..... could i use a n/a 109 block for a turbo application with the exception of changing internals?
750H.P.V6 Brutal 6 Racing Joined Sep 4, 2001 Jun 5, 2009 #2 Yes. You'll have to drill and tap a hole in front of the block for the turbo drain line. Other than that it's the exact same block. Neal
T TURBOELKY Well-Known Member Joined Jun 27, 2005 Jun 5, 2009 #4 750H.P.V6 said: Yes. You'll have to drill and tap a hole in front of the block for the turbo drain line. Other than that it's the exact same block. Neal Click to expand... dang Neal, your fast
C chris96z New Member Joined Aug 5, 2007 Jun 5, 2009 #6 Or tap it into the fuel pump cover if you are not using a mechanical Pump..
F fast400 Member Joined Mar 20, 2008 Jun 5, 2009 #7 chris96z said: Or tap it into the fuel pump cover if you are not using a mechanical Pump.. Click to expand... ???
K KevinB Well-Known Member Joined Dec 2, 2004 Jun 5, 2009 #8 fast400 said: ??? Click to expand... The fuel pump block off plate is an alternative to tapping out the block. My engine uses a n/a block. There is one around here that even went 150+ mph.
B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Jun 5, 2009 #9 KevinB said: The fuel pump block off plate is an alternative to tapping out the block. My engine uses a n/a block. There is one around here that even went 150+ mph. Click to expand... An NA block. SO you got rid of the turbo:biggrin:
K KevinB Well-Known Member Joined Dec 2, 2004 Jun 5, 2009 #10 bison said: An NA block. SO you got rid of the turbo:biggrin: Click to expand... Shhhh....don't give away my speed secrets
