meanchicken
gallo vicioso
- Oct 6, 2007
Howdy.
Recently my test button stopped functioning fully. I press the test button and the LED near my boost gauge lights red, but no Alky is pumping in test mode and the button on the controller does not light. I'm sure not alky is running because I can hold it for several seconds at idle, and the engine will not stumble and O2's stay normal.
The Alky is working normally otherwise. I've been purging my lines recently by boosting while rolling, up to about 5-6 psi and waiting for the red LED to light, and then holding boost for a few seconds with the LED on, then letting out.
I can go WOT at 20psi on 91 octane with the Alky gain nob set to 5 and there is 0 KR. Also the Alky tank level goes down normally when I've had my foot in it and all lights function normally, so the system is functioning normally other than the test button not running the pump.
Suggestions on troubleshooting please?
Is the controller bad?
