turbowannabe
- Dec 6, 2001
Looking for a hydroboost. Can be a hot air unit or aftermarket. Let me know what you've got.
Here’s the link:HydraTech has what you need
I'm considering their kit but it's about 1200 bucks. Seeing if I can track down a hot air hydroboost or a used kit. There is a guy on ebay who sells a nice hydroboost for 600 bucks, just got to buy a mater cylinder and hoses. It'll work with stock hot air hoses which can got for cheapHere’s the link:
Hydratech Braking Systems :: Products
Hydratech Braking Systems :: Show Prepared High Performance Hydraulic Brake Assist Systems - Productswww.hydratechbraking.com
I’d stay away from the hot air set up if you can. The newer Bosch units are current (not 30+ years old) & feature an accumulator on the side that hold enough pressure for 2 applications of the brakes (in the unlikely event you have a power steering failure .
Spend the money this is one area you do not want to compromise your safety !
Hey Kwik, that's a bad ass set up you got, looks awesome (although I prefer the powermaster setup). I also agreed with you buying new and from one vendor, makes life a lot easier. But if you put in the work in, you can sometimes achieve the same results spending a lot less $$, that being said....If it were me, I’d buy it all from one place , it will be plug n play & don’t have to run around grabbing things here & there .
That’s what I did .
HydraTech gets my vote .
Turbo, I just saw someone selling a Hydroboost on facebook for $500, you might want to check it out. I'm not vouching for the seller, I don't know him from Adam, so do your own due diligence.I'm considering their kit but it's about 1200 bucks. Seeing if I can track down a hot air hydroboost or a used kit. There is a guy on ebay who sells a nice hydroboost for 600 bucks, just got to buy a mater cylinder and hoses. It'll work with stock hot air hoses which can got for cheap
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.www.facebook.com
Yeah get me his number if you can. I messaged him last night asking for a current Pic of it but never heard backThe guy on FB Izaac Nelson is a good guy! I have his car right now. Doing some upgrades. He just bought it with Hydroboost installed. So he is selling his other unit which is brand new for $500 it’s the unit from eBay that the guys sells for $600 plus. It’s brand new and can be used with the braided line kit or stock 84 lines. If you are interested in it let me know I can give you his number he’s in Jersey.
Like already mentioned in the 2nd post…. Contact HydraTech, they have a complete hose kit availableGot one coming from tricksix's buddy with a pump rebuilt and upgraded for hydroboost. Just need to fugure out what I'm going to do about hoses. Thanks for everyone's help
I wish I'd seen your post earlier. I have a brand new Hydro boost conversion kit part# KPP7619 from Kirban performance that I decided not to use. Still not cheap but could have saved you a few hundred bucks from the original price.Looking for a hydroboost. Can be a hot air unit or aftermarket. Let me know what you've got.
I will definitely be buying this. ThanksAdd a PSC PS Fluid reservoir designed for HydroBoost & you will be all set!
These even have a built in filter!
Newer hydroboost have a built in accumulator that holds a couple extra brake pumps if your engine dies.Maybe someone will chime in but I wanted to ask the guys using a HB system what do you do for brakes if the motor dies while you’re driving? It happened to me a couple weekends ago driving 90mph down the highway my iccc fuse popped and I had no brakes, luckily the road was empty but if this happened in traffic I would’ve been screwed. TIA
