forcefed3.8's
Buckeye Bullet
- May 26, 2002
This is in my brothers Cutlass hybrid, it weighs 3520 with driver.
Stock 80,000 mile short block, e85, 83lbs injectors, 60psi base pressure, stock ecm with extender extreme chip, home made double pumper with Reds XP pumps, Reds volt booster, hemco upper plenum, stock throttle body, stock intake with the ends of the runners cleaned up, TE63 p trim turbo@27psi, 210/215 roller, stock rockers, comp 853 lifters, pac 1201 springs, mildly ported stock valve iron heads, stock headers, powerstroke front mount with 2.5" pipes, 85mm truck MAS with a custom 3.5" pipe, PTC 17 blade converter, 6 year old Brian Hoffer trans, stock front suspension with cheap replacement shocks, front sway bar removed, stock rear control arms, stock sway bar, air bag with 23psi in the passenger spring, moser axles, stock driveshaft with brute force u joints, old rusty shocks from the 80s or 90s (maybe even the original 1979?) New bushings in control arms, 275/60 MT pro radials. Car has stock welded motor mounts, factory fuel lines and filter.
1.39 60' off 10psi footbrake
10.007@132 27psi, 10.6afr through the run.
