Great thanks!Yes, a flexfuel sensor will plug into the factory MAF connector using this adapter: https://www.turbotweakstore.com/ProductDetails.asp?ProductCode=4005
Great. I'll mess with this tomorrow. Thanks!Having wrestled with the wifi and a cheap tablet, don't get a cheap tablet. Get a good one. The cheap tablets are nothing but trouble. They're slow, and that screws everything up and makes them extremely frustrating. Get a fairly recent Samsung.
Some tablets won't stay on the ECUGN's network because there's no internet access, which makes a mess. They keep hopping off and on the network and Shadow Dash can't stay connected.
As for the WiFi, in the shadow dash settings, there's an option for setting the Wifi connectivity. Make sure you have the right IP address and port. Shadow Dash defaults to the wrong numbers. My ECUGN is listening on port 23 on 192.168.4.1
Which tablet did you go with?I bought a 10" tablet with a USB port built into it cause I was fighting the same issue. Works well
I've just run my first event with a flex fuel sensor added.
It just worked. Beyond enabling the sensor and plugging in the values Eric passed on, I touched nothing. I didn't touch the timing table; I didn't touch the VE table. I just dumped E85 into it and let it figure it out.
It worked just fine:
Can I use this ecu to control a 4l80 transmission?
Thanks.Not without an additional module
