- May 27, 2010
Just replaced my power antenna with a new unit I had laying around for a few years. The only issue my old unit had was broken antenna cable see picture.
After I took it out I fixed it with Kirbans antenna mast repair kit. Cleaned up the inside added grease and re-sealed the unit back up. Knocked off the surface rust on the mast and painted mast. Tested in car and works fine. Took a couple hours to remove and reinstall unit. You will need to reuse your own fender bracket and screw the antenna wire into the mast. Comes with black bezel which guides the mast out. Do not have fender bezel to include with this.
$125.00 shipped lower 48!
Tested and works!!
Tested and works!!
