I just changed to a LT1 MAF w/ a 60# injector and chip street package from TT. Fired it up Sunday and she ran great out the box w/ no adjustments. Today I went to clean up the engine bay a bit and mount my Translator plus in the bay-fire it up, and holy hell, it sounded like marbles all over the place about 15 seconds into start up...sound is very tinny-plus, the SES light came on, and the Power Injection light came on(I thought it was not used...based on the issues I am having I guess the individual before me wired it up to sense some sort of knock issue????) Now, I swapped BACK to the original configuration, which is the original MAF and ran it and here are readings...mind you-they were fluctuating a bit but this was the general range.
398
KR 0??? (I don't understand this)
AF 06
L8 44
BAT 13.2
INT 128
BL 118
MPH 0
CLT 142
ATS 87
R 825
TPS .42
IAC 72
CC 78
NAL 34
Fuel pressure was solid at 45psi
I didn't take reading with the Translator plus installed...I just wanted to shut it down as it sounded horrible. I've looked through the scan master codes, but what seems wrong here to anybody? FYI my translator is set up properly from what I gather at on, on, on, off. Also base is 2, MAF is at 0, and spark is at 0,0. Also, I did not adjust the parameters of the TT chip when I installed it. Under programmable features, it says "YOU DO NOT HAVE TO ADJUST THESE", so I did not. I don't understand-it ran fine a few days ago it seemed, now...I'm afraid to crank it.
398
AF 06
L8 44
BAT 13.2
INT 128
BL 118
MPH 0
CLT 142
ATS 87
R 825
TPS .42
IAC 72
CC 78
NAL 34
