J-B Racing
Forced Induction
- Sep 16, 2003
For those using Gear drive, has anyone got into issues with it? Anything to look out for..
Joe
Joe
There is two versions the later style is better.For those using Gear drive, has anyone got into issues with it? Anything to look out for..
Joe
Claude I have to dis-agree on this one. For those like me and turbobitt using extremely hard springs the Gear Drive once properly installed is a good insurance. I am glad I just installed mine. I don't have to worry snapping the Chain at hi RPM.For all the problems it seems to bring, why don't you toss all of that in the trash and get a good quality true roller timing chain... ... it will get the job done...
Claude.
View attachmentFor all the problems it seems to bring, why don't you toss all of that in the trash and get a good quality true roller timing chain... ... it will get the job done...
Claude.
This the red series or gold series timing set?
Safety wire.Ours the bolts worked loose and fell into the pan. We went back to chain.
the bolts in my gear drive where tack welded then where ground down flush with the back of the gear drive plate . im pretty sure they will not be going anywhere any time soon.Ours the bolts worked loose and fell into the pan. We went back to chain.
I don't have a definitive answer to that question. The heads were assembled by Zimmerman Racing and installed on a Stage 2 motor in a race car I bought. I have the paperwork for the engine but no specs were listed. Once removed they had a number of bent valves, I chose not to rebuild them as I had another set ready to run. As a guess I would say at least 250lbs on the seal and 550+ open.how much spring pressure do you guys run that broke chains?
test the springs and see thats low to brake a chain inmoAs a guess I would say at least 250lbs on the seal and 550+ open.
I don't have the heads any longer, I gave them to Gene Fleury. I'll check to see if he ever pulled them apart.test the springs and see thats low to brake a chain inmo
