Wrong, 2 dogs!Fel-Pro are gaskets. Speed Pro’s are pistons.
Moron Scammer!
for felpro - classic fast .. at track its easy is use tps at 50% for trigger
rpm or many other triggers can be selected from the trigger list
on manual trigger you have to press spacebar, for other method just use the down arrow to right , select the channel you want rpm , tps etc and then the pont that you want it to start
Glad to see you back, giving hard earned advice...for felpro - classic fast .. at track its easy is use tps at 50% for trigger
chose logging>setup realtime logging, then you need to select the dash for logging you want to record
the dash you choose can be set up in FILE> dashboard set up
for other method just use the down arrow to right , select the channel you want rpm , tps etc and then the point that you want it to start
I agree. I’ve read A LOT here & Pace always has good info.Glad to see you back, giving hard earned advice...
Hart007:the post he made seemed legit but after some research .. he is a scammer , boot him chuck
heres an interesting post from 2001
