NorCalTurbos
Slowing down to SPEED UP!!!
- Nov 9, 2013
Thanks for your time first off. My question is about the cat size. I have a HA that I converterted to IC. Are the cat converters the same diameter or is the 84-85 larger where the Dp won't slide over the cat pipe. If they're the same I'm going to cut the ring off the end where the Dp and cat meet & slide my stock 87 dp over the cat and connect it like factory other than that I will be modifying my Dp by adding the 85 dp flange to the 87 dp. Thanks for any info
