WTD: 7675 Gen II or 7685 GenII Precision Turbo
karolko
As the title says, i{m putting out the feeler to see if anyone happens to have a GEN II Precision turbo 7675 or 7685 laying around that they would part with.
Adrian
karolko
yeah, im just trying to kiss the 7´s and be able to drive it on the street and still have a fun car. I currently have a Gen I 7675 and its a great turbo, but i don´t think it will have enough steam to get the job done.
Mr.Spool
Have you tried running it out?and how much does the car weight?
I dont think a gen1 gives that much away to a gen 2.
karolko
I’ve run mine to 34psinand at that point I had 2:1 backpressure.
I now have a new cam which will help and a 25.3 chassis (before it was a roll bar)
The Gen II turbos also have improved airflow so I was hoping that it would have helped with my backpressure issue.
Mr.Spool
Did you try using a bigger ar?
karolko
My current turbo has a 1.28 a/r. The largest precision offers. So I don’t know how much these would be to gain if I went slightly larger.
Are there larger a/r ratios available for a divided T4 gt42 style housing?
Haulz A
Using the Wallace Racing - ET/MPH/HP calculator, based on an 8.72 ET and 156 MPH trap speed- his calculated vehicle weight is about 3575 t0 3600 lbs with the driver. The calculated Flywheel HP is about 1050 with the Gen 1 turbo. A Gen2 7675 turbo will not provide enough additional flywheel HP propel a 3600 lbs vehicle into the 7 second range without reducing the current vehicle weight by approximately 400-500 lbs based on math and physics in my opinion.
Mr.Spool
Dont take this the wrong way but I am well aware of the math calculations which is why I asked the question.
I had no knowledge of the cars weight or et and mph to even program in the numbers.
Not sure why you quoted me.
Mr.Spool
Thankfully the car now weighs 3000lbs :)
At 3000lbs
With 1150hp
You should be in the 7s inmo.
Mr.Spool
That's a big ar for a 76.
BP wont be from that ar.
I have a 7675 on a car here that made 1000rwhp on .96 ar.
Turbo is rated for 1150hp it's older.
Mr.Spool
I completely agree
