Remove the shifter handle, there is a white plastic piece sticking up out of the shifter assy. Twist that white piece counter clockwise which will unscrew it from the rod bringing it up higher which will let it contact the inner workings of the shifter handle to let it move when you push the button on the handle. It is a adjustment of sorts. Make sure your handle is seated all the way down also.
