marleyskater420
still needs to learn
- Aug 14, 2004
We at RPS are incredibly proud to offer special Promotional pricing on the new WORK G4 line of turbochargers!! This promotion is only for the 6765 sized turbo. These ball bearing turbos normally retail for $2,025 but this Promotional price is for $1,795 which is a $200 savings! This Promotion will last only as supplies last!!
These turbos use brand new designed, 100% point-milled compressor wheel that is made in the USA, that flows over 95lbs/min and capable of supporting over 1,000fwhp!
This turbo with the right supporting mods, only requires a 3,000-3,100 stall converter!!! When I mean supporting mods, on a stock block / stock displacement / stock compression ratio engine, the mods would be; ported iron heads, PTC 9.5" converter, E85 for fuel, and a camshaft with at least 208 duration. If your car has those modifications, you would only need a stall speed to spool this converter of 3,000 to 3,100rpm.
The owner of WORK Turbo ran this turbo on his stock block / displacement / compression ratio engine, with a chip, E85, PTC 9.5", and ported iron heads and ran a 10.98" in the 1/4 at 12psi with a footbrake launch of 7-8psi in a 3,807lb car!!!
Details on these turbos:
1) 4" inlet, 2.5" outlet ported shroud compressor cover
2).63 or .85 Buick turbine housing
3) These are built off of Garrett ball bearing center sections and turbine wheels
3) Utilize our point milled 67mm compressor wheel
4) Custom machined compressor cover
5) Genuine Garrett quality bearing and seal structure
6) MADE IN THE USA point milled forged aluminum compressor wheel
7) Bearing housing is coated gloss black for corrosion protection
8) Turbine housing is coated semi-ceramic black for corrosion protection
9) Compressor housing starts off as a Garrett part that is machined to this specific compressor wheel, featuring a fully developed ported shroud inlet for increased airflow as the compressor wheel reaches the choke line.
10) 100% high speed VSR balanced assembly (unit is balanced and tested all the way to full RPM)
These turbos DO require a water line kit, which we sell for $100, and oil feed line fittings for $45. For the oil line fittings we need to know if you have the stock oil feed line or braided oil feed lines. This pricing is not included in the $1,795.
If you have any questions on this unit, please post here / PM me, or email me at 1987GN@gmail.com, or call 707 362 6030.
Thank you for taking the time to check this turbo out!
-Tyler
-Tyler
