Wire harness
The wire harness that runs long the firewall around the trans dipstick tube does it run in front or the rear behind the dipstick.The way i had it it was in front of the dipstick,but it just looks wrong.but it also looks like if i put it behind the dipstick i wont be able to bolt it to the back of the intake maniflod.Can anybody take at look at there's and let me know.
If you're talking about the oval harness that runs from the fuse block to the ecm, it goes behind the dipstick. It is supposed to be attatched to the heat sheild covering the ac/heater box.
Great,thank you.I dont think i have a heat shield on mine but it is attached to the ac box and also there is a loop in the the middle of the harness that i had attached to the rear of the intake manifold,maybe it bolts somewhere else?
