Whole Bunch of Junk ( cheap)
Trader history for m233roller (1)
m233roller
Here are some more Buick items I want to sell and some of these small parts are hard to come by. More parts and pics. below.
1- Throttle body bracket for the cables. Nice. $35
2- IAC housing for the throttle body with bolts. $10
3- 2 new A/C delco fuel filters. $10 each.
4- Good license plate light. $15
5- Trunk release button and the correct mounting bracket for our cars. Out of my 40,000 mile car. $20
6- Perfect C/S rear speaker. $10
7- Plastic & metal dog bones for front bumper mounting. Metal $15 for two, plastic $20 for two.
8- Round dome light with harness & has a led bulb in it. perfect out of my 40,000 mile car. $20. The bulb alone cost me $10.
9- Perfect a/c, heater controls out of my 40,000 mile car. $35
10- Very nice with little use push in breather. $10
11- 3in turn down for cars with an electric dump. Nice piece. $20
12- Refurbished stock thermostat housing and hold down with bolt. $20
13- 86-87 ESC module. $35
14- Good used burgundy shift handle. Handle only. $20
15- Gear selector tongue for console. $5
16- Lower holder for positive cable. One ear is split but a washer will fix that. $10
17- Red T horn medallion. Has very minor little flaw on red T. Hard to even see. $10
18- Steering wheel lower collars ( gray) in perfect shape. $20 each
19- Very nice gray rear seat belt retractors. $30 for the pair.
20- Rear coil pack bracket with the original mounting bolts and the original nuts to mount the ignition module. $20
21- Brand new power antenna mounting nut and spacer. $20
22- Rear original tail pipe brackets off my 40,000 mile car. $40
23- No pics. but also have the frame pads for the motor mounts with the bolts. $45 Off my 40,000 mile GN.
24- All chrome pieces are very nice unless noted.
25- Stock maf sensor cover. $25
26- Accumulator ball cover. $20
27- P/S cap. $15
28- Rad overflow bottle cap. $15
29- Perfect chrome rad. cap. Two years old and maybe 2,000 miles' $20
30- Perfect regular regal flip flop emblem for the header panel. $15
31- Perfect crest emblem. $10
32- Both chrome rad support to fender brackets. One has a little spot by the front bolt hole that has pealed but its on the side and will be hard to even see. $40 for both. I paid $100 for these.
33- Anodized blue catch can with a removeable filter for cleaning. Some scratches on it. $20
34- Excellent charcoal canister with the factory mounting tabs and solenoid. With a pretty new filter in the bottom of it. $20
35- Two front chrome bumper guards In nice shape with nice rubbers on them. $20 for both.
sparky0798
Mike I will take 1 ac Delco fuel filter and number 16. Pm me your info and I will send funds later on tonight. Thanks
grass doctor
Dream Catcher
ill take the t horn medallion...and the gear selector tongue ....and any other of the junk you want to throw my way ...LOL...
m233roller
The rest of it.
A- Factory bolts to mount you console. $5
B- Factory rear drive line straps and bolts. $10
C- All 6 mounting clips for headliner side moldings. $10
D- Hard to find the little bracket that holds you gas lines in place. Bolts to the fuel pump block off plate. $10
E- Big bolt for front balancer. $5
F- Sun visor screws and the little plastic sleeves. $5
G- 6 wastegate rod clips. $5
H- New and original perfect chrome door lock pulls. $5 a pair.
I- Plastic bracket that bolts to your tranny to hold the wiring harness. $5
J- Black plastic bracket on the frame and holds the battery cables. $5
K- Two original starter bolts. $5
L- Factory starter heat shield. $10
M- The two original screws for the vacuum block. $5
N- Almost new dual window switch. $10
O- Kenne Bell blue anodized fitting for the fuel rail. $10
P- New & used cable clips. $5
Q- Two excellent Y's for your wastegate line. $10 each
U- New 30 amp resister. $5
R- Torrington bearing for cam nose. $10 each.
S- Billet aluminum little clamps to hold wiring, vacuum lines etc. $5 each I have used these and they really look nice.
T- Original cam sensor hold down bolt & washer. $5
W- 3 foam seals for park light sockets. $5
X- Fittings for fuel rail for fuel pressure gauge. Straight one $10 Angle one that's new, $15
Y- 6 of the little clips that hold your dash and radio bezel on. $5 for 6
Z- Two right side park lights. One is smoked out & perfect. $15 and the other has a small star rock chip in about the middle and at the very bottom. Very good for a driver. $10
PLEASE NOTE THAT ALL PARTS ARE PLUS SHIPPING!!
THANKS MIKE
HotAirWH1
Hey Mike-
I'll take the:
Q- Y for your wastegate line. $10 (ONE)
gsgns4me
I'll take both pairs of....
Shipping is 25918.
chopped39
Mike
I will take two plastic dog bones and perfect heater controls to 60101
Do you have any shims for the front bumper?
Hunter Dog
Item 9 for me. Trying to find some other items pics, is #5 the cable that would go to the glove box to the back? Trying to find that. Our car did not have this option but would like to install one.
Mike Swentzel
27- P/S cap. $15
Hey Mike I'll take #1, 26, and 29 lmk how much for shipping and I'll send payment Thanks, Mike
