Which looks better
Which look do you like more?
  • Black
    Votes: 13 72.2%
  • Bare
    Votes: 5 27.8%
  • Total voters
    18
T- Type Tim
Vice Chairman
How much is that? Does it bolt right up to vacuum set up?
Bare alumuminum is a great match for your black VCs with aluminum heads (?).
Also much easier to maintain long term if the MC is painted vs anodized. JMO
I'm planning on the black one on a hydroboost setup. I will admit tho with most of our engine compartments having the black and polish theme going, if I ordered one and the black piece was out of stock I wouldn't hesitate for a second to get the black and polished unit.
I’ve got polished aluminum
Didn’t look at baer
Calipers are wilwood
That looks like a nice piece
How much$?
Depends on the finish, but if your set-up is Wilwood I'd probably keep it all the same. I personally have a preference to Baer, that's all. Wilwood is just as nice/good/pretty.
What does your engine compartment look like? Colour scheme should play a bigger role in your choice imo if you already know what master cylinder you are going with.
Master Cylinder is 1-1/8” bore Wilwood #260-8556-BK with Wilwood Adjustable Proportioning Valve #260-1170 with RH Proportioning Valve Bracket #220-15047
