which fuel pump to use
turbo 250
hi guys,
got my new engine together now,just thinking about what fuel system would be better.eliminator 11104 or red armstrong double pumper.i have stroker kit,gn1 heads,95 lbs injectors,215/220 cam,72mm turbo and 3500 stall(400turbo with trans brake) thanks for any help
With a 20% safety factor using 95 lb injectors you will need select a pump and line to flow 94 gph@75 psi or 575lb/hr approx. I would ask armstrong the flow rates of his set up and see if they are within that spec. Within a few days i will have a fuelab pump and will tell you what i think of them.
This is a good write up on pumps. Looks like the xp pump is ok at over 14 volts
Tuning
From the graph in this post:
http://www.turbobuick.com/forums/ge...1-fuel-flow-graph-bigger-pumps-injectors.html
The 100# injector curve is close enough to 95 but is a bit more so it will give some margin. Looking at the manufacturer's published data for their pumps, there are quite a few that will cross at more than 70 psi. The Weldon 2015 crosses right at 70 psi, so it may be iffy (but if you only run 80-85% dc it should be ok). In order of increasing capacity from there:
Aeromotive A1000 - 75 psi
Fuelab 41402 - 76 psi
Aeromotive eliminator - 80 psi
SX 18207 - 81 psi
Weldon 2032A - 82 psi
