Where to get turbo gaskets?
Hafrod
I read that FelPro discontinued the gasket kit for our turbo mounting, egr, and drain back tube. What do we do for gaskets?
It looks like egr and drain back gaskets are the same as 86-7 but just going off pics. I did go through my massive gasket hoard and found a 3 bolt flange header collector gasket that the 3 bolt holes line up on the intake but it has a bigger opening on the gasket 2.55" I just ordered a 2" and 2.25" id to try. The intake hole is 2". The 2" id gaskets bolt holes are just barely shy of the intake bolt holes and I'm thinking they will work best. That's if my Harbor Freight digital caliper is not lying to me ;)
You're right on the EGR and drainback gaskets - they aren't special.
The turbo-intake gaskets is tricky to find. It's about a ¼" thick. That important to getting everything else to line up.
