Where to buy EGR vacuum lines?
87we410877
See below. Where can I get this vacuum line set up? New please. Or used in very good condition.
Any auto parts store will have them. I believe it’s 7/32 vacuum line and cut to length.
No No no. These are pre-formed vacuum lines, filter, check valve or whatever that thing is on the right (Piece broken off that goes to a hard line)
The white piece on the right is a 3-way check valve, you can find it in the HELP section of advanced auto or Kirbans sells one.
The preformed lines can be replaced by regular vacuum lines with a check valve in series. Or, you can find people on here who sell off their original equipment lines and solenoid after they go the EGR delete route.
Awesome thanks!! I figured out a way to make my own pre bent lines ;) and this is a 100% restoration. They need to be bent as factory not straight pieces.
