Where can I purchase a braided oil return line/turbo coolant line?
NorCalTurbos
Slowing down to SPEED UP!!!
Gbody has the feed, and I think I remember a while back finding a return, not sure where tho, you might have to fab something up.
NorCalTurbos
Try TR Customs for the oil drain/ return line looks simple to make one at home to your own specs good luck post pics if you come up with something
Toby_Goodmk
Test Fit officianto
I have what you are looking for. I have a feed line, the correct AN fitting as well as a 125$ return line made of stainless steel that I cut the end of the 87 style off to make it fit hot air. Let me know if I can help
NorCalTurbos
image.jpg trcustoms has this
TurboRegal84
Moderator
Staff member
The TR customs one will not work for the 84/85 because the return line slides into a grommet on the intake and the 86/87 is threaded in. The best style return line used on my 84 was the original 86/87 (because it was longer) with the nut cut off.
Toby_Goodmk
Test Fit officianto
yup, that is what I did, and have available.
