Whatta waste of time........
Lockman
Appreciate and Admire other' s Knowledge
So..... After my new injectors install. I did not get the oil drain seated in the grommet . I was anxious to run & tune, so I took the precautionary , misguided step of applying high temp RTV on the perimiter. Ran my rig & put it thru the paces for about a week at different times. Oil drip ...... every time.
Removed this mess on Sunday:
I had a brandie new grommet in stock, so I said to myself : ' Self, I can save some dough & fab up my own drain tube."
So.......after 4 hours of :censored: , I ended up with this pile of :poop: :
So........ I ordered GBody Parts replacement Turbo Drain Hose. It's coming along with my back ordered billet vacuum block., hopefully late week ?.
I'm going to take a nap now. :sleep:
Lockman
Addendum :
I realize that i am fortunate as hell to have over 10" of space between my turbo outlet & my firewall
Jerryl
Tall Chinese Guy
Make sure to tie wrap the other houses on the T, and everywhere they lead to.
The DS of the T feeds the FPR and the PS is supposed to feed the MAP sensor. Not sure if your setup uses the MAP, but if it comes off or leaks, you will loose pressure to the FPR and could have a very bad day.
