what stall are you running with bolt ons stock block?
Jerryl
Tall Chinese Guy
Dec 14, 2004
8,128
826
113
Houston, Texas
"Stock long block and stock turbo, e85, 2800 Stock re-stall"
So assuming max 22 PSI, my opinion is; Stock stall D5, locked @ wot, with a GOOD transmission.
FWIW; I have a local buddy who has a NLU trans, stock long block with valve springs (intake has never been off) TE44, 93/alky, 27-30 PSI for about 10 years. He tried a few converters and all slipped way too much for the operating RPM. He just got a 9.5 PTC spec'd by/from Bison. Should be good to go.
  • Like
Reactions: seedling
bpman1234
1,809
102
63
south florida
thanks jerryl .going to a 400 the converter is a tci -241000 10 1\2 " they call it variable pitch.i think its 24 -28 or 3000 stall it was behind my 455 olds big block.any one know about this converter?will it work ?
ITSAV6
It's my Granny's car!
Nov 13, 2001
2,147
136
63
Ocilla,Georgia
sogaturbobuicks.4t.com
A 2800 12" converter will work differently than a 2800 10" or a 2800 9" I have a 2800 9x11 converter and it works well with my TE61 It does 1.65 60ft leaving at 2800 on foot brake and isn't real loose on big end. Locking in 3rd around 4500 picks up 2 mph but no significant et. I'd love to get a PTC 9.5 non lock or Dave's 9.5"
Boost231
What's An Intercooler
Staff member
May 26, 2001
14,765
839
113
35
SoCal
www.arizonagn.com
Try it and find out
  • Like
Reactions: Jerryl
Jerryl
Tall Chinese Guy
Dec 14, 2004
8,128
826
113
Houston, Texas
As stated; Any converter not designed or spec’d for your combo may not work well.
Too tight, and the car will respond like a 2 legged dog.
Too loose and the slip will do nothing but transfer the energy into the fluid and heat up, instead of getting it to the tire.
My advice; PM Bison and have him spec a converter for your GOALS and combo.
A new converter won’t be near as expensive as the aggravation to drop the transmission twice.
Good luck.
  • Like
Reactions: rmar and Hahny
David Husek
Turbo Buick Performance
yes just wondering with my sig in a 10 " what's stall ?
I can spec and build you the correct torque converter for your car. I don't sell another vendors product. My designs are spec'ed for the turbo Buick application only. Pump design and stator choice are very important when it comes to turbo cars. I am not sure if there is another Turbo Buick anyone whom designs and builds there own. For more info contact me directly
jthomas
50
6
8
58
I originally had a Vigilante converter and it worked well, but David built a torque converter for my setup and all I can say is the difference was night and day. David’s converter woke my combo up and it puts a smile on my face every time I punch it. Give him a call...you won’t regret it.
  • Like
Reactions: Turbo Keith
Top Bottom
