- Nov 30, 2009
I went to BG this year for the first time and had a blast !! I also got a chance to try and get my car dialed in , in the 1/4 . This is the results from the first 5 runs right off the trailer in the heat and humidity of BG with tuning in between each run . Each run was reviewed with Power logger and the main tuning changes were to the 1 - 2 gear and 3 - 4 gear timing . The timing was very conservative @ 17* 1 - 2 and 15* 3 - 4 with zero knock . After each run A/F was checked and was already set to a conservative 10.8 . Each consecutive run we increased timing , checked for knock , A/F , fuel pressure , rpm shift points . We finished at 21* 1-2 & 20* 3-4 with AF @ 10.9 and zero knock . Boost was at 29-30 psi for all runs . It looks like 9.9999 might not be out of reach !!
